Inventor General Discussion
Valued Contributor
24 Kudos
Post 1 of 30
Template Help! for Inventor IDW
393 Views, 29 Replies
12-30-2013 08:18 AM
I have a IDW Template and want to change it so that when I bring in a IPT the lines of the drawing are in blue color
1. Open the template file.
2. Manage > Styles Editor, expand the Layers Node.  Assuming you are talking about the "Visible Edges".... pick "Visible Edges" in the left pane. Now in the right pane, find the " Visible Edges" layer and change the color to what you want it to be. Click "Done" to exit the Styles Editor.
3. Now you have to write this to your Styles Library. On the Manage tab, Styles and Standards panel, click "Save".  If your library is read/write, this will write your changes to the library.
4. Save the template and exit.
Start  a new idw using this template and see if it works when you bring in a part.
Valued Contributor
24 Kudos
Post 2 of 30
IDW template
12-30-2013 08:26 AM in reply to: rnewcomb
49 Kudos
Post 3 of 30
Re: Template Help! for Inventor IDW
12-30-2013 08:28 AM in reply to: rnewcomb
Open your template file, then go to the manage tab and select "Styles Editor". Click the + symbol next to layers, and select "Visible" lines. Click the colored block under "appearance" and change it to the color you wish. Make sure and resave as a template.
Cybertron PC
Intel Core i5-3470 CPU @ 3.20 GHz 3.60 GHz
16.0 GB RAM
Windows 7 Professional 64 Bit
3D Connexion Space Pilot
Inventor Professional 2014
Autocad Mechanical 2014
49 Kudos
Post 4 of 30
Re: IDW template
12-30-2013 08:30 AM in reply to: rnewcomb
Cybertron PC
16.0 GB RAM
510 Kudos
Post 5 of 30
12-30-2013 08:39 AM in reply to: rnewcomb
Valued Contributor
24 Kudos
Post 6 of 30
Re: IDW template
12-30-2013 08:40 AM in reply to: chad38
I did do that but it still isn't coming in blue
49 Kudos
Post 7 of 30
Re: IDW template
12-30-2013 08:42 AM in reply to: rnewcomb
You must save the style into the style library, otherwise it will replace the template file styles with the style from the library. So after you finish editing the style, you have to click to save the style into the style library.
Cybertron PC
16.0 GB RAM
Valued Contributor
24 Kudos
Post 8 of 30
12-30-2013 08:44 AM in reply to: karthur1
ok, mine says read only, how do I change that to read/ write
49 Kudos
Post 9 of 30
12-30-2013 08:48 AM in reply to: rnewcomb
Go into projects, in the bottom pane, right click on "Used Style Library" and select Read-Write.
Cybertron PC
16.0 GB RAM
Valued Contributor
24 Kudos
Post 10 of 30
12-30-2013 09:02 AM in reply to: chad38
Thank you for the help, I got it to say read/write but it still isn't coming in the color I want, any more ideas?
