I made some changes to our normal template file for inventor and saved it to my hardrive in the public folder. When i open through windows explorer its fine and everything is correct. When i open a new idw and select this file through inventor it comes in with some of the tables having different size text and none of my leaders comming in. Any help would be greatly appericated.
Did you do a "Save As Template"?
The first time i made the Template i did a save as a template. Now i just go back into it edit and save the changes.
How do i check which styles i have it set for global or local?
Ok I opened the file from windows made my changes to save copy as template file. No change. I opened original file with style library in read-write saved styles changes under manage tab click yes to all but nothing shows up. Clicked save anyways closed, changed back to read only no change....What else can i try? thanks for the help so far.
Hi
first set your style librairy to resd write
2- open your template and don't save a copy to template
3-when you try to save your style the change made in the librairy style should be listed if yes save the style
another thing, if you have created new partlist style or anything else you must create a new object default style and you must link the new style to your standard style, see pictures.
maybe it's not clear
send me a private message and if you want, share your screen with team viewer and i will set your template.
