Inventor Forum
TempEmbed_(1).bmp in Inventor DWG when opened in AutoCAD
0 REPLIES 0
Message 1 of 1
302 Views, 0 Replies
Hi There Guys
Hope all is well and someone is able to help.
I am having this issue quite frequently and am getting very frustrated. I have a few embedded images in my Inventor DWG Template and when I open the drawings up in AutoCAD all images dissapear and instead get replaced with TempEmbed_(1).bmp. Sometimes it works and there is nothing wrong, and other times I get the TempEmbed(1).bmp "replacement". Once this happens there is no way to recover the images, the only solution which works less then 10% of the time is to save the file as a different name, and then rename at a later stage.
We recently moved to 2013 (always run 1 year behind) and the issue above has become alot worse. Any non-migrated documents (2012) seem to work, but those migrated to 2013 do not.
I have searched the net and read a few posts, but none seem to have an actual solution, and know one knows if its an Inventor or AutoCAD problem.
Any help would be great.
Brett
0 REPLIES 0
