Inventor General Discussion
Active Contributor
rms390
Message 1 of 3 (249 Views)
Tell me why i can't insert a frame member.
249 Views, 2 Replies
01-17-2013 11:40 AM
Try to generate a frame member. When it fails, tell me why.
Curtis_Waguespack
Message 2 of 3 (247 Views)
Re: Tell me why i can't insert a frame member.
01-17-2013 11:45 AM in reply to: rms390
Hi rms390,
Please attach the required part files as well. Keep in mind that an assembly file is just an empty "bucket" into which you place other files and then assemble them.
It's also generally a good idea to state the version of Inventor you are using so that someone with Inventor 2013 does not work up a soloution for you that you could not access if you had Inventor 2012, for instance.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
rms390
Message 3 of 3 (232 Views)
01-17-2013 12:58 PM in reply to: Curtis_Waguespack
Sorry this can be closed.  I checked it into and out of vault and then it magically started working.
