I am using task scheduler to print idws to PDF. It works fine however it prompts me to save each file. I want to start it of Friday and come back and have it done. How do I automate this task?
From what I remember you have to modify the settings in the actual print driver. If you are using Acrobat to make PDF's, RMC on the Adobe PDF printer icon in you printer control panel and select Printing Preferences. From there you can set up an output folder. If it says something like "prompt for file name", change it to something else.
Good luck!
OK, Gonna give a try. Thanks
