Hello
Please advise
I need to export my IDW drawings to DXF.
As long there are lot of files I wish the Task Scheduler will do that job.
It actually does but only with "File" option. I mean I cannot take a whole Folder
since there is no DXF option and should click each file and set the DXF there.
The second big problem it returns zipped DXF files, I cannot get rid of that. Please advise how?
Is it about the ini file??
Orest Yavtushenko
Solved by alessandro.gasso. Go to Solution.
Hi Orest,
I hope the attached video can help.
Kind regards,
Alessandro
Alessandro
Thank you for the great advice!
I have checked it, it works great!
I am sure it worth more than one kudos but I can check only one.
I have a lot of plates to be cut by laser. Guys need DXF and it must be
2004 one. I can do both get rid of zipping and at once set the 2004 version,
work more surely with less errors and spend at least an hour more smart
vs clicking between Inventor-Scheduler-Mechanical..
Thank you,
Orest Yavtushenko
