Inventor Forum
Task Scheduler - Reinstall
11 REPLIES 11
Message 1 of 12
2919 Views, 11 Replies
Hi All
My task scheduler crashes as soon as I dbl click on it, does not even go to
main window.
Is there a way to only reinstall this part of INV Suite
Wayne's PC
Inventor 2009
32Bit Edition - 2GB
XP PRO SP2
Intel Core 2 Quad CPU
Q6600 @2.40GHz
4GB RAM
NVIDIA Quadro FX1700 512MB
11 REPLIES 11
Message 2 of 12
ColinWang
Hi Wayne,
You can use the following steps to reinstall Task Scheduler
1. Log in OS as administrator.
2. Win+R to open the Window Run dialog.
3. Enter "Inventor path\Bin\RegisterTaskScheduler.exe" /install or "Inventor path\Bin\TaskScheduler.exe" /install
If it can't solve your issue, please download the attached file[TaskScheduler.mdb] and use it to replace the original file which is in the Inventor Path\Task Scheduler folder.
Note: please backup the original mdb file before replace it.
Hope this can help you.
Best Regards
-Colin
Message 3 of 12
Hi Colin
This did not work
is there not an install.exe on any of the
disks?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
Wayne, You can use the following steps to reinstall Task Scheduler 1. Log in
OS as administrator. 2. Win+R to open the Window Run dialog. 3.
/install If it can't solve your issue, please download the attached
is in the Inventor Path\Task Scheduler folder. Note:
please backup the original mdb file before replace it. Hope this can help you.
Best Regards -Colin
Message 4 of 12
ColinWang
Hi Wayne,
There isn't an installer for Task Scheduler only. Please check if Scheduled Tasks of windows have any task. If there is any task, please delete them. And you can reinstall or repair inventor to fix it.
Have you replaced the mdb file? Could you tell me what task you launched before Task Scheduler failed.
Best Regards
-Colin
Message 5 of 12
Hi Colin
I could not download the MDB you sent it was
blocked can you maybe ZIP file it for me.
I cant get into Task Scheduler at all when I DBL
click the icon the windows error messaged comes up straight away, so I canty see
what tasks were running at all.
I have done a repair and am trying to avoid
reinstall
I have also excluded MDB files from my anti
virus
anything else i can do?
regards
Wayne
Hi
Wayne, There isn't an installer for Task Scheduler only. Please check if
them. And you can reinstall or repair inventor to fix it. Have you replaced
failed. Best Regards -Colin
Message 6 of 12
ColinWang
Hi Wayne,
Please download the TaskScheduler.zip and use it replace the original mdb file. Did you use Task Scheduler before?
Best Regards
-Colin Edited by: Sheng.Wang@autodesk.com on Mar 16, 2009 3:40 PM
Message 7 of 12
magnus.damgren
Hi
I've followed this thread and done the suggested procedure as I have the same problem with two of three machines.
I've attached a Zipfile containing error message and dump information. I've also attached the machine NFO file for all three machines.
This is a very annoying problem.
Message 8 of 12
toma_pera
I think this is the same issue that was discussed here
http://discussion.autodesk.com/forums/thread.jspa?messageID=6094698ェ
But no solution were found.
Autodesk, any idea?
Thank you for your help!
Thomas.
Message 9 of 12
Hi Colin
I have replaced the original MDB file with the one
supplied, still no joy.
Suppose reinstall is now on the cards.
Hi
Wayne, Please download the TaskScheduler.zip and use it replace the original
mdb file. Did you use Task Scheduler before? Best Regards -Colin Edited by:
Message 10 of 12
einszweidrei
Hello Wayne,
I have the same problem. I reinstalled Inventor2009 complete, the problem is still the same. By using a limited user- account my task scheduler works 😞
Did you find a solution for your problem?
Windows xp pro 32bit, Dell precision T5400, 4GB RAM, nvidia quattro fx 1700. IV Suite 2009 SP 2
Edited by: on May 22, 2009 6:18 AM Edited by: on May 22, 2009 6:19 AM
Message 11 of 12
Hi there,
Had no joy with this I am hoping to fix this on
install of 2010.
Let me know if you find any other
solution
Regards
Wayne
Hello
Wayne,
problem?
Message 12 of 12
jfire
in reply to: ColinWang
I have searched and I can not find this folder on my computer running xp   inventorPath.  could you tell me where this is located in what directory.
Thanks  jfire
