Save one file manually using the settings you need.
Unfortunately the Options button in TS has limited functionality 😞
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5982751@discussion.autodesk.com...
I need to convert about 50 idw files to dwg files. I need to convert to 2004 file format. Task scheduler is set for 2008. (I'm
using IVPro 2008).
How do I change default prameters to save in a different file format?
Dave
