Inventor General Discussion
RD-Digitek-USA
Message 1 of 4 (559 Views)
Task Scheduler error
559 Views, 3 Replies
10-14-2011 06:14 AM
OK, the only version of Inventor I have ever ran on my new workstation is R2012. So can anyone tell me why, when I try to run Task Scheduler, I get the error "The last Autodesk Inventor version used on this machine does correspond to this version of the Task Scheduler. Please run and close Autodesk Inventor R2012 before running Task Scheduler"?
*Pro
ampster
Message 2 of 4 (551 Views)
Re: Task Scheduler error
10-14-2011 06:41 AM in reply to: RD-Digitek-USA
is it possible you or someone else installed a older trial version of Inventor on this pc in the past?
Do you happen to have Inventor running when you launched the TS?  Close down Inventor before running TS in that case.
RD-Digitek-USA
Message 3 of 4 (545 Views)
10-14-2011 07:14 AM in reply to: ampster
It's a bran new computer, only R2012 has ever been loaded on it, I am sure of that. I have tried both with Inventor running and not running.
This all started when I tried to use Design Assistant to rename some files in an assembly. I got a message that a couple of library parts needed to be  updated to the current release before they could be edited. I picked "OK", thinking I didn't plan on renaming the library parts anyways. Design Assistant loaded the assembly but everything was grayed out, I couldn't edit anything, which is totally ridiculous!
I then figured I would use Task Scheduler to migrate my library files and ended up with the Task Scheduler issue. Very frustrating! I have a deadline looming and am dead in the water again.
Inventor has many incomplete and useless error messages like this one I received this morning. Come on AutoDesk what am I suppose to do with this Gibberish? AutoDesk need to tighten up their code.
Error in rule: Sheet_Scale, in document: T006-50 (Part Enclosure).idw
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.DrawingDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D467-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
*Pro
ampster
Message 4 of 4 (535 Views)
10-14-2011 08:12 AM in reply to: RD-Digitek-USA
sorry I can't help with the Task Scheduler error, odd!
But I suspect you are correct in that the files need to be migrated up to 2012 and the error msg's you are receiving are related to that...
Now how to get around that, is the question.
