Inventor Forum
Task Scheduler and run API/macro
3 REPLIES 3
Ktelang
1292 Views, 3 Replies
Hello Everybody and Autodesk,
Is there a way by which I can run a vba - macro over all the file in a folder using
Task scheduler,silently
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
3 REPLIES 3
bobvdd
in reply to: Ktelang
Defining yourself a custom Task Scheduler task is probably the way you want to go, if you are not afraid of some programming Smiley Wink
You might want to read my support blog article where I use iLogic rules in a custom task in Task Scheduler.
The same mechanism (with some extra work) can be used for running macros via a custom task.
Not sure what you mean with "silently". You don't want to bring up Inventor API and use Apprentice API instead , or you want to run Inventor in silent mode? Both can be done depending on teh actiosn you want to perform on the files.
Bob
Bob Van der Donck
Principal UX designer DMG group
Ktelang
in reply to: bobvdd
Thanks Bob,
So far I am not afraid of programming Smiley Wink not great at it though
but can do something which works for me Hope that stays that way.
I will look into the blog.
And yes Silent means in the background
brendan.henderson
Have a look at KwikBatchRun here http://kwikmcad.com/icode/KWiKBatchRun_64/KWiKBatchrun_64.aspx
I use it and it works great. Only $20 USD per seat. No affiliation, just a happy user of the program.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
