I have MS Office 2007 and use Excel a lot during normal Inventor sessions but have never paid attention weather I run Excel prior launching Inventor.
I have Windows XP Professional with SP3 installed in a HP notebook (6530b). Graphics card is integrated to the mother board and is an Intel Chipset 4 series. I have struggled to find a workable hardware configuration for the Ribbon UI to display properly. Here's the Inventor diagnostics:
This graphics driver is fully certified.
Graphics Hardware Description: OpenGL \ Microsoft Corporation \ GDI Generic
Graphics driver file igxprd32.dll is version 6.14.10.4953
Using the GDI-Generic driver
The display is using 32-bit color
Inventor Version:
Build: 253, Release: 2010 SP1 - Date: Wed 07/29/2009
32-Bit Edition - 2.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
Content Center
Inventor Vault
Autodesk DWF Markup Manager
AEC Exchange
Content Center Item Translator
Frame Generator
Drag & Drop Interoperability
Design Accelerator
AutoLimits
Inventor Studio
EDM Addin
System Information:
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.090206-1234)
Language: English (Regional Setting: Spanish)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq 6530b (FS245LA#ABM)
BIOS: Default System BIOS
Processor: Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz (2 CPUs)
System Memory: 1978MB RAM
Page File: 1520MB used, 2347MB available
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DxDiag Version: 5.03.2600.5512
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2009/01/15 14:56:43 $
Windows XP
Original driver information:
GDI Generic
1.1.0
Graphics HW Vendor Supported for Autodesk Inventor: False
rating 3, optimization level 2
Optimization Level = 2
Options = 0
Warning Options = 7
Hardware Library 2.0\Microsoft Corporation\GDI Generic
Settings for optimized and conservative:
SwapType: 3, 3
Workarounds: 0x01000206, 0x01000206
Workarounds2: 0x00000000, 0x00000000
Text Options: 0x00000000, 0x00000000
OpenGL Version: 11, 11
Recommended Optimization Level: 2
Texture Font Precision: 32
Driver Rating: 3
Inventor Version Tested: legacy
Using OpenGL 1.1
swap behavior: swapExchange(3)
OpenGL errors: None.
GL_EXTENSIONS: GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
Pixel Format = 7
Bits per pixel: Color 32, Depth 32, Stencil 8
GL_MAX_VIEWPORT_DIMS = 16384 x 16384
GL_MAX_TEXTURE_SIZE = 1024
Graphics driver log information:
Ago/12/2009-12:59:21: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/12/2009-13:13:00: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/12/2009-13:14:51: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/12/2009-13:15:59: User changes the graphics driver manually: OpenGL -> D3D9.
Ago/12/2009-13:41:09: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/14/2009-13:06:34: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/14/2009-13:07:04: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/14/2009-13:07:52: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/14/2009-13:08:06: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/14/2009-13:08:30: User changes the graphics driver manually: OpenGL -> D3D9.
Ago/14/2009-13:08:40: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/14/2009-15:25:41: User changes the graphics driver manually: OpenGL -> D3D9.
Ago/28/2009-11:26:17: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/28/2009-11:28:19: User changes the graphics driver manually: OpenGL -> D3D9.
Ago/28/2009-11:31:27: User changes the graphics driver manually: D3D9 -> OpenGL.
Ago/28/2009-12:19:46: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/28/2009-12:54:19: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/28/2009-13:03:40: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/28/2009-13:05:39: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/28/2009-13:07:07: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Ago/31/2009-10:09:07: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Sep/01/2009-10:06:41: Fail to create OpenGL factory, We need to change it for current inventor session: OpenGL -> D3D9.
Sep/02/2009-15:13:41: User changes the graphics driver manually: D3D9 -> OpenGL.
Sep/02/2009-15:33:31: User changes the graphics driver manually: OpenGL -> D3D9.
Sep/02/2009-15:33:53: User changes the graphics driver manually: D3D9 -> OpenGL.
Sep/02/2009-15:34:41: User changes the graphics driver manually: OpenGL -> D3D9.
Sep/25/2009-08:53:40: User changes the graphics driver manually: D3D9 -> OpenGL.
