Inventor Forum
Tapped Hole Error
21 REPLIES 21
Message 1 of 22
alcuratolo
640 Views, 21 Replies
Tapped Hole Error
I cannot use tapped hole option in my hole feature menu.
And I cannot edit any previously created tapped hole features. I have: XP Pro 64 bit
Inventor 2008
Office 2000
This problem occurs with only one user, 11 other workstations do not have this error.
21 REPLIES 21
Message 21 of 22
lukerz
in reply to: alcuratolo
I can understand your issue because I am experiencing the same thing at work. I then decided to check it out at home and both the tapped holes and thread functions performed fine. The only thing that I can think of is the OS. Most of you are running Windows XP where I am running on Vista... Edited by: lukerz on Apr 6, 2010 12:16 PM
Message 22 of 22
I have attached the same document as Word 2003 format. Hope you can open this. Please try the steps in this doc and see if it helps or not. It would be great if you can report back if it worked or not.
Regards
shekar
