Inventor Forum
Taper extrude problem
22 REPLIES 22
Message 1 of 23
cpakl
1273 Views, 22 Replies
Dear All,
I want to have a taper cut both sides.
Taper is coming both sides I want taper only on one side.
Is it possible I do not want to add one more feature.
Also I do not want any other feature than extrude due to some limitations.
PLEASE SUGGEST SOME WAY......
22 REPLIES 22
Message 2 of 23
robvacsax
in reply to: cpakl
As JD would say " do you have a file or picture available of what you are trying to achieve?"
Rob
Rob - User since release 10
System specs
Inventor 2020
Processors: 8x Intel core i-7 7820X 32GB ram
Video: NVIDIA Quadro P100
Message 3 of 23
JDMather
in reply to: cpakl
>...I want taper only on one side.
Wasn't this clear to you Rob?
Message 4 of 23
mflayler2
in reply to: cpakl
What possible reason would you have to limit your features to Extrude only? Seems like you are making your life more difficult for no reason.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 5 of 23
robvacsax
in reply to: cpakl
If A=C-B
and B=C-A
and C=A+B
What does D=???
System specs
Inventor 2020
Message 6 of 23
in reply to: cpakl
Do the cut without a taper, then apply a face draft.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP2, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://teknigroup.com
Message 7 of 23
cpakl
in reply to: cpakl
Ok,So the sketch plane is in between the part.
I want to to have a cut which is through all.
I want taper cut on one side of plane & straight cut on other side in one feature.Is it possible?? That was a simple question.
Message 8 of 23
mflayler2
in reply to: cpakl
Not by using just the extrude command. You would have to do a cut and then a fact draft if you only want on side to have a taper. Or you would have to do two separate extrusions using the same sketch by sharing it.
Message 9 of 23
mcgyvr
in reply to: cpakl
What you ask is not possible in one feature only...
But again why are you limiting yourself to using only one single feature?
There are many ways to do what you want but none in one mouse click/feature
Message 10 of 23
JDMather
in reply to: cpakl
>I want taper cut on one side of plane & straight cut on other side in one feature. Is it possible?
Maybe, can you post the file?
It might have a simple one feature answer. Can you post the file.
Message 11 of 23
JDMather
in reply to: cpakl
How can you make that determination without seeing the file?
Message 12 of 23
parag27276
in reply to: cpakl
Unfortunately I can not post the file.
But I got the answer that I can not do it in Inventor with one feature.I have the limitations of the standard parameters so I can not have two features.
May be I will try with other program.
Message 13 of 23
JDMather
in reply to: cpakl
Can't you make up a simple sample file that exhibits the behavior you want in your proprietary file.
>But I got the answer...
I can think of at least two ways in Inventor depending on the geometry.
>Maybe I will try with other program.
What program would that be?
Message 14 of 23
mflayler2
in reply to: cpakl
I agree, a simple file would not break confidentiality and if you could use another feature other than extrude you should still be able to use existing default parameters. Such as a Sweep for instance.
Message 15 of 23
billco-mfg
in reply to: cpakl
If you use equations, I don't see why standard parameters would force you to use one feature. Every dimension could be a function of one standard parameter if need be.
You probably see a decent benefit from posting a simple example.
Message 16 of 23
hallstevenson
in reply to: cpakl
Will one of the face draft options allow it to "stop" ? By default it will draft the entire cut.
Message 17 of 23
dan_inv09
in reply to: cpakl
He's got a plane that defines where the taper will end. He will probably have to do a split to the surface.
Message 18 of 23
mcgyvr
in reply to: cpakl
because you can't extrude both ways from a sketch plane and taper only one side (per the OP's question stated above) in inventor today...
Thats how the determination is made.. No file necessary assuming the question was stated correctly.
Message 19 of 23
billco-mfg
in reply to: cpakl
If I understood you explanation, will one of these do?
Message 20 of 23
hallstevenson
in reply to: cpakl
That will require an add'l feature/step which he's insistent against having.
It will work though....
