Inventor General Discussion
New Member
Adam.Fetsch
Message 1 of 3 (221 Views)
Tangential Movement
221 Views, 2 Replies
12-14-2012 08:11 AM
Hi all!
I'm working on a little trackless train at the moment, and could use some help.
I have a working model of the train going around a curve, but I cheated a bit, by constraining the center points of the axles to the curve, and then had the wheels angles based off the drawbar angles.
I have began working on a more accurate version, where the angled wheels are what drives the carts around the curve.
Long story short, if you have a thin playing card in Inventor, how can you restrict motion in the normal direction, allowing the card only to translate tangentially no matter how it is orientated in the model space?
Constraints are all based on relationships between two parts. Is there such a thing as restricting a part's movement in certain directions?
The reason I ask, is I would like the wheels to follow the direction they are oriented (not being dragged in a normal direction, something resembling slip motion)
Essentially, I would like to do this without using contact friction between the ground and the wheel (which is what actually makes the wheel follow the direction of its orientation in real life).
Any suggestions? Probably not so clear eh?
*Expert Elite*
JDMather
Message 2 of 3 (184 Views)
Re: Tangential Movement
12-15-2012 09:14 AM in reply to: Adam.Fetsch
I think you will have to become familiar with the Dynamic Simulation Environment.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
New Member
Adam.Fetsch
Message 3 of 3 (155 Views)
12-17-2012 04:31 AM in reply to: Adam.Fetsch
I wish. Our firm only runs standard Inventor 2011. That means no dice for Dynamic Simulation.
I was trying to think of some sort of dummy object underneath each wheel which would not allow the wheel to translate in any direction other than straight ahead.
I came up short.
Any idea with normal constraints? Honestly, if you can't figure this one, no one can! :smileyhappy:
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
