Inventor Forum
tabulated charts
6 REPLIES 6
1003 Views, 6 Replies
tabulated charts
Ok PRo's
I have made a steel die part and put holes in the part and also put threaded holes in the part, now I want to create a hole tabulation that calls out each hole and also tells the info for the threaded holes as well.
like...  0.2570 hole drilled  and tapped to 5/16-18 UNC
6 REPLIES 6
mcgyvr
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-C8BCD600-830A-4110-B9D8-9364FF0BAD21
or create a general table and manually populate it or insert an excel table..
blair
in reply to: mcgyvr
You should be able to pull that data up and bring it into the Hole Table. RMB on the table, select the Edit Table, select Formatting from the Tab-Options, then select the COlumn Chooser. You may need to change the Formatting to get the desired number of decimals.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
in reply to: blair
OK, THANK YOU, iT DID ADD THE COLUMNS BUT IT DID NOT PUT THE INFORMATION IN THEM? it ONLY ADDED A - IN EACH SPOT??
blair
Check your model, did you use the Hole Feature or did you use the Extrude Feature? It works fine here, brings in the Drill Hole Size and Drill Tape Size.
Delta Tau Chi ΔΤΧ
I used hole feature
in reply to: blair
oops, I was adding the thread from the thread feature and not in the hole feature. now it works...
