Ok PRo's
I have made a steel die part and put holes in the part and also put threaded holes in the part, now I want to create a hole tabulation that calls out each hole and also tells the info for the threaded holes as well.
like... 0.2570 hole drilled and tapped to 5/16-18 UNC
Solved by blair. Go to Solution.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-C8BCD600-830A-4110-B9D8-9364FF0BAD21
or create a general table and manually populate it or insert an excel table..
OK, THANK YOU, iT DID ADD THE COLUMNS BUT IT DID NOT PUT THE INFORMATION IN THEM? it ONLY ADDED A - IN EACH SPOT??
