Inventor General Discussion
Distinguished Contributor
billco-mfg
Message 1 of 21 (144 Views)
table displays equation instead of value
144 Views, 20 Replies
01-04-2008 06:45 AM
I'm detailing an iPart. Only two dimensions need to be included in the table. One is the driving dimension and the second is a function of the driving dimension. How do I get the column for the second dimension to display a value, rather than an equation?
Inventor Routed Systems 2010
Subscription Advantage Pack SP3
Vault Collaboration 2010
Windows 7 x64
Dell Precision M6400 Covet
billco-mfg
Message 2 of 21 (144 Views)
Re: table displays equation instead of value
01-04-2008 07:19 AM in reply to: billco-mfg
I figured out a way, but I wonder if there is a simple formatting option.
I added all the parameters involved in the equation to the iPart table. Then I replaced the equations I had in Inventor with Excel equations. This is a messy solution, since it forces you to add a bunch of otherwise unnecessary columns to the ipart table.
Windows 7 x64
Active Member
daveyfinchy
Message 3 of 21 (144 Views)
01-11-2008 01:50 AM in reply to: billco-mfg
Hi
Have you found a solution yet?
I've got a similar problem where a dimension I want to show on the drawing is not an actual perameter, but a formulated value based on a few perameters.
Don't quite understand your suggested solution? Can you explain it more, thanks.
Dave
*Expert Elite*
dan_inv09
Message 4 of 21 (144 Views)
01-11-2008 07:39 AM in reply to: billco-mfg
If the second parameter is driven by the first, why does it need to be in the table? You only change/pick the first value, right?
billco-mfg
Message 5 of 21 (144 Views)
01-11-2008 10:03 AM in reply to: billco-mfg
The overall length of the part is a function of another dimension. I need to show the OAL on the drawing, so I need it to appear in the table.
Windows 7 x64
billco-mfg
Message 6 of 21 (144 Views)
01-11-2008 10:17 AM in reply to: billco-mfg
I think I'll need to keep using the method I posted.
Before the part was an iPart, there was a parameter defining the length of an opening (B). Another parameter defined the overall length of the part (A, where A = B+4).
When I detailed the part, I decided that I needed to show two dimensions in a table, OAL and OpenWidth. When I added A to the table, the values displayed a 'A+4' insteadd of just showing the resulting value. If I edited the table via Excel and did the math inside the Excel cells, then just the value appearrs in the table.
Windows 7 x64
*Expert Elite*
dan_inv09
Message 7 of 21 (144 Views)
01-11-2008 10:30 AM in reply to: billco-mfg
Ahh, I missed "detailing," didn't read carefully enough.
How are you making your table? If you just put the spreadsheet on the drawing, how do you handle all the extra stuff inventor needs in the column headers?
Have they improved the way inventor deals with spreadsheets in drawings? I gave up trying several releases ago.
billco-mfg
Message 8 of 21 (144 Views)
01-11-2008 10:57 AM in reply to: billco-mfg
There is a table command now that lets you select an iPart or iAssembly table as the data source. Once the table is placed, you can format/select the columns and hide rows.
Windows 7 x64
*Expert Elite*
dan_inv09
Message 9 of 21 (144 Views)
01-11-2008 11:21 AM in reply to: billco-mfg
Despite the screen name I am using 2008.
I've played with the new table command a little. It has some potential but now this is another limitation.
billco-mfg
Message 10 of 21 (144 Views)
01-11-2008 11:40 AM in reply to: billco-mfg
I don't know if it is a limitation or if I'm just unaware of the simple solution.
Windows 7 x64
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
