Hello all,
I have a question pertaining to the out of the box styles used within Tube and Pipe. First let me start by saying we are using Inventor 2012. I am looking for an out of the box style to use that will give me lapjoint flanges with stub ends. Does anyone know if any of the pre-existing styles are capable of producing the lap joint with stub ends, on flanged ends of your run, without having to manully replace fittings and adding stub ends.
We don't use a lot of lap joints here but the project I'm working on now requires it. I'm not currently able to make a style because we have too many users and don't have write privelages to Author. So definitely looking for out of the box styles. Thanks ahead of time for any help on this one. It's greatly appreciated.
Thanks a bunch
Solved by cbenner. Go to Solution.
@Anonymous wrote:
Hello all,
Thanks a bunch
Welcome to the forums.
I'm not aware of anything out of the box for that style. I think this is something you will need to create as a custom. Do you have the parts available from the Content Center? I'm not in Inventor right now so I can't check to see if they exist. But that's half (or more) of the battle.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Hello thanks for your reply. I didn't think so but I wanted to run by some of you guys that use T & P all the time. Yes I have all the components in Content Center, I will just have to make a new style. Thanks for the input. It's greatly appreciated.
Regards
Cadman2011
No problem, that's what we do! LOL
Chris Benner
