Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
System Requirement for Autodesk Inventor Professional 2014
10 REPLIES 10
Message 1 of 11
jyothissurendran
1305 Views, 10 Replies
I have Autodesk Inventor Professional Suite 2010 Installed in my system and its running very slow sometimes (Getting Fatal Errors is usual) I am planning to update our version to Inventor 2014. So please advise What is the system requirment for Autodesk Inventor Professional Suite 2014.
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
10 REPLIES 10
Message 2 of 11
mpatchus
in reply to: jyothissurendran
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15402497&linkID=9242018
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. šŸ™‚
Message 3 of 11
Cadmanto
If you google search exactly what you typed in for this question you would have found your answer.  Smiley Wink
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 11
mcgyvr
in reply to: Cadmanto
Whats a "google" ? šŸ˜‰
Message 5 of 11
stephengibson76
in reply to: mcgyvr
http://bit.ly/uxMA6H
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 6 of 11
jyothissurendran
I did the same as you suggested, i made the post after that to get some expert's  advise.......
Jyothis Surendran
Windows 10
Message 7 of 11
Cadmanto
Understood now.  You should state that in your opening post, that you have already looked at the Autodesk website and would like the advise of experts or users persea.  Smiley Happy
Best Regards,
Scott McFadden
Message 8 of 11
mcgyvr
You are asking for system requirements.. It can't get more "expert" than the system requirements page on the website of the company that created the software..
Message 9 of 11
Cadmanto
in reply to: mcgyvr
I think what he is saying, is he wants the experience of users to state how and what equipment has worked for them.
I do agree with you, that the Autodesk website is the best place to go at least as a bench mark.
Best Regards,
Scott McFadden
Message 10 of 11
JDMather
The minimum system specs are on the Autodesk site as you have found.
For more detailed information you will need to explain what you typically do.
Assembly size?
Part complexity?
Desktop?
Laptop?
Inventor Studio, Dynamic Simulation or FEA?
Other things that are important to your line of work?
In general - plan for a system that will suite your needs for the next 3-4 years.
As much RAM as you can afford.
SS hard drive for the OS.
Are looking for monitor specs too?
This can quickly turn into 20 questions.
When was the last time you completely restored your current system.
 Every 3 or 4 years I will finally get around to returning an old system to it's out-of-the-box condition.
Install all Windows Updates and graphics driver update.
Install MS Office and Inventor....
...and I'm always astonished how much better the old machine runs and why I waited so long to do this.
(in fact, I always seem to do this right after purchasing a new system and then regretting not waiting a little longer till getting my new system, which is of course already out of date when I unpack the box)....
Message 11 of 11
jyothissurendran
in reply to: JDMather
Assembly size?
Part complexity?
Desktop?
Laptop?
Thanks Mather.... Your Replays always helps me lot..
I am using it for some kind of Structural designs, Using it in desktop, Inventor Professional Suite 2010 (Updating to 2014).
Jyothis Surendran
Windows 10
