Hi Dennis,
Does that mean that in order for the property to update automatically, that the drawing iproperty must be used on the drawing sheet?
In our case, we don't use any of the drawing iproperties in the drawing title block. Instead we use the iproperties directly from the model.
The issue is that I need the properties between the ipt & idw syncronised automatically for the sake of vault searching. Currently, if I have the project field populated in the ipt and then I search in vault for that project, only the ipt appears in the search results.
I know that I can update them manually but I am trying to find an automated solution.
I have tried an iLogic rule, however, I had a problem with the one I created. The sync workd well, however, when it was active the drawing was always in a cycle of requesting that I save it even though it had just been saved before I was attempting to close the file.
@nbradbury wrote:
While in the drawing environment if you go to Tools>Document Settings and then select the Drawing tab there is a button at the bottom that says "Copy Model iProperty Settings..." This allows you to choose what model iProperties are initially copied to the drawing, note that is initially, the iProperties in the drawing will not update.
With the Bonus Pack for subscription users in 2009 you could download an addin that created a new button in the Tools menu called "Update Copied Model iProperties". If you modify the ipt or iam then open the drawing you can use this tool to update the drawing iproperties, it is still not automatic and it has bugs. If you create a block in model space using AutoCAD Mechanical then the tool stops working. I have not installed 2010 yet so I don't know if the "Update Copied Model iProperties" is included and I don't know if it has the bugs worked out yet.
In short, there is no automatic update and you can only force it with 2009 or newer.
Just curious if there was an improvement on this feature.
Does anyone know if its possible to automatically sync (not manually clicking a button) model & drawing properties now?
Hi Guys,
I could be wrong but I thought such workflow already existed. Open a drawing template or a drawing file. Go to Tools -> Doc Settings -> Drawing -> click Copy Model iProperty Settings -> check "Copy Model iProperties" -> check "All Properties" -> Ok -> Close. Save the template or the file. When the first view is created, the model properties will be copied over to the drawing properties.
Is this not working as it should? I will need to see a defective example.
Many thanks!
