We are switching to Vault & Inventor 2013.
Using previous versions, we have added a lots of custom parts to Content Center, Libraries (Vault), we also have custom templates.
Can anyone describe what would be the safest way to migrate all necesery data to 2013 Inventor version?
We had our VAR in our facility last month descussing this very topic.
What they told us is the migration from 2012 to 2013 should bring all of those
kinds of things over (i.e. libraries, CC). As far as the templates they told us once
2013 is loaded, to simply call up each template and resave it in the new version.
One thing I would add is if there are personal settings on each machine, make sure those
individual settings are saved to a file. Then they can be reinstalled once 2013 is fully loaded.
Hope this helps.
I agree with Scott. And add a couple of notes.
Make sure you have a backup before the migration. Then make a backup of the backup.
Use your VAR to handle the database migration which will include the custom CC stuff.
Use task Scheduler to migrate your files. We only batch process Library files and handle Project files as we open them, mainly because they are historic and not used every day like Library files (we have 2 project files, Library and Projects). Task Scheduler can be a bit of a pain so only migrate about 500 files at a time. It can be run on several machines concurrently though to help speed things up. Best to do overnight when no other user is accessing the database.
We have done this 4 times now with minimal troubles. 1 key note is when using Task Scheduler and migrating IDW files to look at the options and consider the SET DEFER UPDATE setting (I think I have it named wrong but you will find it). In some versions it is on by default so after the migration each time an IDW is opened it gives a warning message and you have to manually turn the DEFER UPDATES off. A pain for the unknowing.
Best of luck. I will be going through this again next Feb for 2012 to 2013 upgrade.
