Hello, i am testing animating a camera a long a 3d sketch path. i created just a simple 2 direction 3d sketch using precise input, then put a fillet between the 2 segments. The help tutorial says that you can use a 2d or 3d sketch to animate a camera path, this does not work however. when i try and fix the camera position to the path it will only grab one of the 2 segments. Is this not possible? Using inventor 2014 pro. thanks
Hello,is the path continuous from one end to another without a break?
Try it as a single arc to see if it works.
Warren
good morning. yes it is continuous. if i use a 3d spline or arc it works fine, but if i use the 'line' command in 3d sketch it doesn't create a usable path. i have made sure that the segements are connected via a fillet between them.
