Hello all,
I'm quite new to 3D sketching as most of the components we create are using sheet metal. I was just curious if anybody has a more efficient way of modelling the attached part than the way I have done it.
I created various 2D sketches then projected these sketches into a 3D sketch where I then rounded the corners. The critical dimensions are the overall height, width and depth so I have used Trig functions for the other dimensions.
Solved by JDMather. Go to Solution.
Yeah it seems alright. The only thing I might have done differently is planned the part so that I could use two of the three origin planes to create your sketches instead of having to move your UCS and create new planes, 2D sketches and 3D sketches.
I've attached an image since I'm in 2014 and cannot send you a part file.
My part uses only the origin planes for sketches. I would also note that instead of using trig, you could just sketch in your curves in your 2D sketches. I'm thinking you may be under the assumption that you need the 3D sketch to get the full path but you can, in fact, sweep across mulitple 2D sketches so long as they connect at a point and do not create an overlapping result.
Hope this helps. Let me know if something I've said doesn't make sense.
Looks like too much work to me?
I did without any trig or extra workplanes.
The Sweep
Sketches 1 & 2
Sketch3
3D intersection sketch (actually the Bends could be added here rather than fillets in the 2D sketches - I didn't check, but might be more correct for the two bends at compound angle).
So now you have two possible techniques that do not require trig or extra workplanes.
