Dear All,
I am just new here and have a question, and hope i will get the answer here 🙂
I am using Inventor 2013 and trying to use the sweep tool to generate the upper part of this Bread form, which has (its section) non-Regular thickness
I prepared a technical pdf File to show the case clearly..
please an advice ...
thanks in advanced
Solved by JDMather. Go to Solution.
I don't have time right now to fix your part - but it is a simple question of order of operations.
The attached file might give some ideas.
Hi JDMather
thanks for replay, with the Round forms there were no problem !!
the problem appears only with the non-Regular forms, please sse my attached files
thanks
Is something like this what you are trying to do?
