Shoulda Known
Check iCF for crossover-assy (IV7). It's a little shaky but so am
I. Just turn on the weldment environment and apple welds. Left them out
so it's easier to analyze construction. The Width Constraint doesn't
always update properly and I can't find the trouble spot. Oh well,
you'll get the idea.
darvin
"Lucas" wrote in message
news:B13622836C27E777FEAF2703B85C2A23@in.WebX.maYIadrTaRb...
> I forgot to mention that this has to be in an assembly context. I
would like
> to get an idw of all the pipes in the intersection as well as a
weldment
> drawing.
> "darvinv" wrote in message
> news:4D90794F466B0233811B72CAA3EF6182@in.WebX.maYIadrTaRb...
> > Using a combination of sweep and extrude to a construction surface
you
> > might? be able to accomplish what you need. I put a little example
in
> > iCF. Sure would be nice to be able to sweep to at least a surface,
face
> > would be better.
> > darvin
> > news:780DF51307A5685A42CAFDF68F97C7E1@in.WebX.maYIadrTaRb...
> > > Patrick Berry wrote:
> > > > You can't directly do a sweep to face (another big wishlist
item,
> > > > along with 2 rail sweeps) so you have really only have one
choice.
> > > > Sweep the pipe past the faces and then trim it to fit.
> > > > Pat
> > > > news:FEAAAA87348A1DFA9F22D9EE1A65CD3C@in.WebX.maYIadrTaRb...
> > > >> I would like to draw a sweep of a pipe between two cylindrical
> > > >> faces. The pipe is welded at both ends to the cylindrical
faces.
> > How
> > > >> can I do draw this efficiently?
> > > >> Lucas
> > > Gotcha Berry. Now how would I go about trimming an intersection
> > between 3
> > > pipes?
