Inventor General Discussion
Active Contributor
1 Kudo
Post 1 of 11
sweep problem
221 Views, 10 Replies
07-20-2011 01:49 AM
I am having problem with my sweep, My trajectory profile path is on the surface and the othe other one is trajectory but it doesn't work
please help me
Active Contributor
1 Kudo
Post 2 of 11
Re: sweep problem
07-20-2011 01:53 AM in reply to: na57zim12
I want to make a part like this
Active Member
1 Kudo
Post 3 of 11
Re: sweep problem
07-20-2011 01:56 AM in reply to: na57zim12
The way I see it, create a tooth first and then circular array it.
Greetings,
E. Peter
Autodesk Inventor Ultimate 2012
Active Contributor
1 Kudo
Post 4 of 11
Re: sweep problem
07-20-2011 02:49 AM in reply to: eddy
how to do this, i am working on it 3 days.
by sweep or anyother ?
200 Kudos
Post 5 of 11
Re: sweep problem
07-20-2011 03:25 AM in reply to: na57zim12
and which version of Inventor???
Only going to annoy people if they spend time creating an example for you to say you're on a previous version and can't open it.
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
200 Kudos
Post 6 of 11
Re: sweep problem
07-20-2011 03:31 AM in reply to: na57zim12
looking at the dwf I dont think sweep is the answer (and I'm wondering how it will mould).
personally would use surfaces as each "tooth" looks like a extrusion (presumably with a taper to be moulded) but instead of being a distance it's "to" a surface revolved around the body.
1) revolve body
2) revolve curved top of tooth as a surface
3) create a sketch on the base and extrude a tooth to the surface
4) create the hole on the inside
5) pattern extrusion and hole
129 Kudos
Post 7 of 11
Re: sweep problem
07-20-2011 03:32 AM in reply to: na57zim12
You can try create a Loft feature starting in your sketch15 and end in a point (points also available to create Loft features) and then by giving the centerline to better control the loft shape.
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
Active Contributor
1 Kudo
Post 8 of 11
Re: sweep problem
07-20-2011 03:36 AM in reply to: sam_m
inventor pro 2012
200 Kudos
Post 9 of 11
Re: sweep problem
07-20-2011 04:12 AM in reply to: na57zim12
I'm on 2011 so can't open your ipt and edit it.
here's a quick bodge that kinda resembles the dwf.  Tbh, with more time I'd redo it and probably come up with something cleaner (especially for the tangent of the top surface to the draw-angle of the extrusion).
1) revolve the body
2) revolve a surface for the top of the tooth
3) extrude a surface for the exterior of the tooth
4) create "inside" surfaces of the above
5) sculpt a solid tooth
6) sculpt away the inside of the tooth
7) fillets
8) pattern sculpts and fillets
quick and dirty but might give you some ideas how to do it on your model.
(still have no idea how you would expect this part to be moulded/made though).
Valued Mentor
134 Kudos
Post 10 of 11
Re : sweep problem
07-20-2011 04:45 AM in reply to: na57zim12
Hi
To achieve your sweep roll up the EOP below sketch 15
create intersection point(working point) with construction plane 15 and radius on sketch 15
after edit the sketch 16 and apply coincident constraint on end line and projected working point
try to built your loft with parallel condition and that's it
after use sculpt feature.
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
