Inventor Forum
Sweep imported structural profiles
2 REPLIES 2
1043 Views, 2 Replies
I want to sweep a I-beam along a 3d sketch to create a conveyor. I will be using different shapes at times so the profile won't always have the same shape, sometimes a small I-beam or a large one or possibly square tubing.
I know I can create the profile and dimension it but is there an easy way to import the profiles from Frame Generator into the sketch or another way without having to create and dimension the sketch?  Or is this one of those tasks you just can't avoid?
Kim
2 REPLIES 2
yannick3
Hi
If your path is made with line and arc, i suggest  to use directly frame generator and use merge option.
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Tags (1)
in reply to: yannick3
Sorry, I was thinking backwards.  I was thinking I had to sweep a profile when all I have to do is create the 3d sketch and use the Frame Generator on it.  I was making it more complicated than it was.
Duh!!
Kim
