I have a sweep that follows the shape of the path sketch, but the sweep itself is made to the right of the sketch. How can I get it to fall directly on the path? Thanks in advance for any help. I have attached a picture of the sweep as well.
Solved by JDMather. Go to Solution.
Attach the ipt file here.
It is not possible to edit jpg files in Inventor.
From the picture it doesn't look like your profile is on the path?
It doesn't look like your profile is perpendicular to the path?
I only added the jpeg to show you guys what i was talking about. I did figure it out though. I just aligned the profile with the path like you said. Thanks
