Inventor Forum
Sweep did not produce meaningful result
3 REPLIES 3
1373 Views, 3 Replies
I'm working on this project for school. It is basically a frame for a small golf-cart-truck thing... long story. The frame is designed to elimante as many welds as possible and be bent on a CNC bender. Anyway I created this 3D sketch from a few 2D sketches and a 3D curve, which was much easier than trying to make it from a 3D sketch alone. I'm trying to sweep the pipe profile around the path. The first section works fine, but when I try to add the splines at the end, it gives me a "did not produce meaningful result" error. The preview works fine and looks great. Is there some way to fix it? Thanks in advance for the help!
3 REPLIES 3
wilkhui
Hi Jared,
Thanks for posting your part, looks like you've found a bug! I've logged 37656 for the failing sweep.
I'll be back in touch soon, hopefully there's a workaround.
Cheers,
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
wilkhui
Hi again,
Looks like the curvature in Sketch8 is too high for this particular profile. Here's the high curvature area:
If you take a look at the curvature of sketches (activated by right-clicking on a curve and selecting "Display Curvature") you can usually get a good idea of the trouble areas. For instance, here's what I saw in the bit I mentioned above:
I reduced the curvature by pulling the handle in Sketch8, circled with the direction below:
The difference is subtle (and I'm not sure why the curvature 'comb' changed from green to blue) but here's how the 'comb' looks after my edit:
I was able to create the sweep after doing that:
Hope this helps but feel free to shout out!
Indy
Product Owner - ASM
Autodesk, Inc.
in reply to: wilkhui
That makes sense, thanks for looking into it!
