Hello, i used to use Solidwork's sweep-cut with a solid body feature but i can't find it in Inventor now. Any suggestions?
Procedure:
In part file;
Create a second solid body (must be axis-symetric, like revolved feature),
Create a path that intersects with the solid (can be a line or a curve),
Sweep the solid along the path with cut command.
I need this where the sweep-cut with a profile is not enough, to get surfaces obtainable by milling on a cylindirical body on a helical path.
There is no EOP marker in Inventor View. I think you will have to post the part with the EOP at the bottom of the browser.
that looks okay, i will try this in ESPRIT as soon as i can to see if i can get the right milling path. if no problems occur, i will mark it as the solution. thanks for your time doug
Create a workplane at the end of the spline curve, sketch the cutting tool profile and then cut sweep along spline curve.
Helixmode -
you "solution" is incorrect.
Looks like solid sweep has just been added to Solid Edge ST9. Come on Autodesk, please put this in Inventor!
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
All,
I created a new post regarding this, asking if there's a way to simulate the effect of sweeping a solid in a sample file I posted. You can take a look here: Sweeping a solid?
Any input would be appreciated. Thank you.
