Hello all,
Can anyone help me on how to do a sweep cut on this edge? I tried many time still not successfully operate. Maybe the way I sketch is not correct. Can anyone show me the best way?
Attach is image and file. The yellow line is my path and Sketch 139 is my profile.
Thanks All.
Solved by JDMather. Go to Solution.
That's been no easy task. EOP needs to be pulled back down.
Walter
Walter Holzwarth
Walter
If it were my model, I think I would start over from the beginning using what I learned from this atttempt in making a more efficient model.
You'd be having some troubles too, Jeffrey.
Look at the red faces, or try thickening of the yellow faces towards the inside of the groove.
Walter Holzwarth
Thanks, I think need to resketch, this file is from one of my customer also.
