did something change in 2013 as far as the way surfaces are displayed in an idw? the surfaces always always had to be "included" in a idw view. now they come in as regular geometry.
Solved by Shiva_Sundaram. Go to Solution.
I am not sure i'll have to ask. Quickly can you show me how you'd turn them off in a veiw rep and not have them show up on something simple
THE PARTS OF THE ASSEMBLY HAVE SURAFECES SKELETON AND OTHER COMPONENTS DERIVED IN AS SURFACES. jUST CAN'T GET TURNING THEM OFF TO WORK
Hi! I would like double-check with you regarding the potential workflow leading to the behavior. When a formerly invisible surface become visible in an associative design view, did you recall doing the following?
In the part containing the surface body, suppress and unsuppress the derived surface or composite node.
Many thanks!
well anytime i edit way of the parts i have to go through each drawing sheet and turn the surfaces off in every view of the drawing, it's unreal how much time this takes in a big drawing package.
