Yes, remove the deleted face operation. If you want it hollow, you will use
the shell command and pick the bottom face to be deleted, but that may fail
at this point due to the ribs and any small feature. Roll up your end of
part marker before the ribs, if that is what you need to do, and then apply
the shell.
You can pick all your ribs and other common radius fillets in one step, or
use patterns to reduce feature history.
wrote in message news:5867402@discussion.autodesk.com...
SO if you delete a face on a solid, it instantly becomes a surface?
Well that definately makes since.
Sorry, my mom dropped me on my head when I was little.
