Inventor Forum
Surface offset disabled InventorLT 2015
3 REPLIES 3
wim
1256 Views, 3 Replies
I created a simple surface in Inventor LT 2015 but cannot offset the surface.
The command remains disabled (grayed out).
Is this because I use the LT version?
Tags (2)
3 REPLIES 3
JoyceZhou
in reply to: wim
Could you upload your dataset so I could have a try? Thanks!
Joyce-Jinghua Zhou
Inventor QA Engineer
PaulMunford
in reply to: wim
Is there a check box on the offset command in LT called 'auto blend' or something like that (I'm not in front of Inventor right now).
It's near the bottom of the dialogue. Try unchecking it...
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
wim
in reply to: PaulMunford
Sorry for late answer.
The thicken/offset command was hidden (for me :-)) behind the combine command, while I was used to find it in the surface menu.
So I added the thicken/offset command to my user commands menu tab and there it remained disable.
Meanwhile I found the right place and all is working fine.
I cannot even reproduce the same thing right now
Thanks for quick reply,
Wim
