El,
There is no direct way to do what you want but there is an indirect way.
Part feature suppression can be driven by parameters. As a result, you will
need a parameter to be the driver and set condition when the feature should
be suppressed. Here is the detailed steps.
Let's assume you have a part with a fillet feature.
1) Create an Excel spreadsheet with a variable called, FilletControl. When
FilletControl equals 1, the fillet feature will stay. When FilletControl
equals 0, the feature will be suppressed.
2) Link the Excel spreadsheet to the part via Parameters dialog. Then
FilletControl becomes a linked parameter.
3) Right-click on the fillet feature->Properties. In the properties dialog,
the top portion allows you to set the conditions in step1. Set up the
conditions, click OK, and save the part.
Now you can change feature suppression status by just changing FilletControl
value in the spreadsheet. The next step is not necessay but it helps you
manage it in an assembly context.
4) Start an assembly and place the part. Link the Excel spreadsheet to
assembly via Parameters dialog or Insert->Object. After that, you will be
able to edit FilletControl value by double-clicking the Excel spreadsheet
icon in 3rd Party folder
An example of what I just described is attached. Let me know if you have any
question.
Thanks!
Johnson Shiue
Test Engineer
(email: johnsonDOTshiueATautodeskDOTcom)
"EL (INV11-SP2)" wrote in message
news:5590517@discussion.autodesk.com...
Anyway to suppress a feature of a parts within a assembly when changing
representation?
EL
