Inventor Forum
Suppressing a Feature in a Derived Part
3 REPLIES 3
466 Views, 3 Replies
I have a part (hyd. piston shaft) that is 1st Rough Machined, then Welded, and finally Finish Machined as a Derived Part. It has an optional shoulder on the shaft that I want to be able to suppress in the final Finish Machine, but dont see the option other than going back to the  original Rough Out and suppressing it there...
Thanks!
Jess
3 REPLIES 3
jeremy_wasserstrass
Is there a reason you are not doing the machining in a weldment assembly? The only way I know of to remove a feature in a derived part is to use the Delete Face tool with the heal setting checked.
Using Inventor 2022 on Windows 10
Ideas needing support: spur gear tooth profile, rack gears generator
in reply to: jeremy_wasserstrass
yHANKS
Cadmanto
Did you resolve this or are you still having this issue.
If you are, can you post your file with a detailed explaination of what you are trying to do and what you want the outcome to be?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
