I have a part (hyd. piston shaft) that is 1st Rough Machined, then Welded, and finally Finish Machined as a Derived Part. It has an optional shoulder on the shaft that I want to be able to suppress in the final Finish Machine, but dont see the option other than going back to the original Rough Out and suppressing it there...
Thanks!
Jess
Did you resolve this or are you still having this issue.
If you are, can you post your file with a detailed explaination of what you are trying to do and what you want the outcome to be?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
