I have an I iAssembly that contains a base part and then 16 other parts that are split into 2 groups (left side=8 ,right side=8). I would like to use a form with a drop down selection box to chose the desired component for the left side and then another form to chose the right side. When the desired component is selected I then want all other parts on that side to be suppressed.
I could create a matrix in the iAssembly table and make a line for each combination which had the correct parts included or excluded but I have no idea how I would then drive this from a user friendly form.
Is it possible to switch between IAssembly configurations using forms/rules?
Any hints, suggestions,code would be much appreciated
