I am trying to suppress part that are labeled as "Reference" on the BOM Strutcture and I can't get the program to cycle through the subassemblies. The following code runs through all the components on the top-level assembly but I can't get it to cycle through the subassemblies. Any help would be great, thanks.
oCompDef = ThisDoc.Document.ComponentDefinition oAssemblyComponents = oCompDef.Occurrences Dim oOccurrence As ComponentOccurrence Dim oSubOccurrence1 As ComponentOccurrence For Each oOccurrence In oAssemblyComponents If (oOccurrence.BOMStructure = BOMStructureEnum.kReferenceBOMStructure) Then Component.IsActive(oOccurrence.Name) = False Else Component.IsActive(oOccurrence.Name) = True End If Next
I have an easy task for you guys....
I have main assembly where iLogic rule is placed. In main assembly is subassemly (lets call it "ASS2"). In this subassembly is part (lets call it "PART1") which I want to suppress if something is true.
So my if sentence goes like this:
if LENGHT > 500 then 'LENGHT is dimension in main assembly
component.isactive("PART1") = FALSE???? ' here I want to suppress in ASS2 PART1
else component.isactive("PART1") = TRUE????
end if
help please
thank you very much
Tadej
In my testing the ilogic snippet "component.isactive("PART")" can only take effect on the first level of the main assembly or if used internally in the sub assembly. You have to use the API to access the occurrence in the context of the main assembly. A custom level of detail needs to be activated first. Hopefully this is what you were thinking of.
The basics of the occurrence recursive loop is referenced from this link.
https://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Sub Main ' Get the active assembly. Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition 'Create a level of detail so we can change the suppression state of the occurrences Try oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations("LevelofDetail1").Activate Catch oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("LevelofDetail1") End Try Logger.Info("Main Assembly:" & oAsmDoc.DisplayName) ' Call the function that does the recursion. Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1) End Sub Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, _ Level As Integer) ' Iterate through all of the occurrence in this collection. This ' represents the occurrences at the top level of an assembly. Dim oOcc As ComponentOccurrence For Each oOcc In Occurrences ' Check to see if this occurrence represents a subassembly ' and recursively call this function to traverse through it. If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then 'Print occurrence to see the structure Logger.Info("Assy Occurrence:" & Space(Level * 3) & oOcc.Name) 'We know the sub assembly we want to target is in the first level If oOcc.Name = "ASS2" Then 'Recursive loop sub assembly and supply back suboccurrences Call TraverseAssembly(oOcc.SubOccurrences, Level + 1) End If End If '------------------------Do Something with occurrences found--------------------------------------- If oOcc.DefinitionDocumentType = kPartDocumentObject Then Logger.Info("Part Occurrence:" & Space(Level * 4) & oOcc.Name) If oOcc.Name = "PART1" Then If LENGTH > 500 Then
oOcc.Unsuppress Else oOcc.Suppress End If End If End If Next End Sub
