Hey guys,
So we are working with a new client who requires dimensions to be in decimal inches with inch marks after the nominal dimension. [2.50", 2.50"±.003, etc.]
What I can't get Inventor to do for me is put an inch mark after the nominal dimension like that. It seems no matter how I set up the dimension/tolerancing styles, my inch marker comes after the tolerances. [2.5±.003"]
I'm using Inventor 2015.
Any guidance?
Thanks!!
Hi ScottBoggess,
I took a quick look, but I didn't see any way to get the results you're wanting.
I hope this helps.
Curtis
There is no way to do it because if your dimensions are in decimal than is means it’s using inches. A lot of clients would be okay if you put “ALL DIMENSIONS DISPLAYED ARE IN INCHES” somewhere in the title block or in the notes.
I hope this helps.
JD
