Hi, I am working with Inventor 2013 Professional. For some reason, after a crash last night, Inventor takes anywhere from five to twenty seconds to perform simple tasks. Things like Constraints, geometry projection, and saving are taking way too long. This is all of a sudden. Any tips would be appreciated.
(Note CPU usage..)
EDIT: This is a simple project consisting of 10 simple parts.
Thanks-
Have you restarted/shutdown your computer?
Running a Space Navigator? 3DConnexion Control Panel > Calibrate
Windows Restore to the point you created when everything was swimming?
Didn't create a Restore Point? Lesson learned!
Repair Install
Uninstall/Reinstall
Clean uninstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
How many geometry projection do you have?
This is a big performance issue....
Thanks for the responses guys, I did a repair from the installer.
That did the trick.
Regards-
JD, can you please elaborate on this a little more, please?
Thanks so much!
@Anonymous wrote:Running a Space Navigator? 3DConnexion Control Panel > Calibrate
Repair Install
Uninstall/Reinstall
Clean uninstall.
Clean Install
Thanks much!!
-Tylor
