I don't know what has happened, but i started a new sketch and the dimensions i place are all driven, they don't control the length of a line, for example
Solved by JDMather. Go to Solution.
Can you post the offending part.
Chech this (see attachment).
No problems here, I assume it's the small horizontal line.
It seems I cannot reproduce the issue.
Is [Driven Dimension] button pressed on your Ribbon?
-Sami Harada
Inventor Framework QA
