Hello everybody,
I have a very annoying thing happening to me right now.
I'm working on an assembly that has several subassemblies. Some of them locked by others. One of such assembly has some constrain errors that really don't affect me. But every time I place/change any constraints of my own, or move any of the components in the main assembly, a prompt keeps appearing. (Please see the attached image for details…)
Is there a way to accept this warning once and for all (or at least until the end of the session)?
I waste an enormous amount of time clicking the accept every 10 seconds.
If the default action when hitting enter would be "Accept" instead of "Cancel" it would be a lot less annoying...
Checking the "Do not show messages for pre-existing problems" doesn't solve the problem.
If anyone has an aswer to this, it would be much appreciated.
B.
Solved by cbenner. Go to Solution.
Well, it sound slike the constraint errors ARE affecting you. My first piece of advice would be to fix or delete the troublesome constraints. Barring that, you can check "Defer Updates" under Application Options\Assembly. Changes that you make will not update until you implicitly tell them to, and you'll only get the message when you do an update.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
You could always call the person who has the subassembly locked and ask them to fix it - - - EVERYTIME THE WINDOW POPS UP!
"Did you fix it yet?"
"No, I didn't get to it."
"Got to go, I need to make a call." ring "Did you fix it yet? Hang on." ring "Did you fix it yet?"
It'll get fixed.
Thanks cbenner!
Defer updates is the option that I was looking for, sadly that is not a perfect solution either...
But I guess you're right... Deleting the constraint IS the best option, even if I can't save the broken assembly on exit...at least it will not bug me this session.
dan_inv09, I really laughed at what you wrote. I wish I could do that :))
