I am working on a new concept design for one of our custumers. A criticial design parameter is the weight of each of several sub-assemblies.
I have an idw of the top level assembly where I have added Parts Lists of each of the critical subs to show the weight of the components used in each sub assembly. I would like to add a line at the bottom of each Parts List that shows the total weight of that sub assembly. I would also like the header of the Parts List to display the Part Number (from the sub assembly iprops).
Is there a way to get whay I want from IV? I am currently using IV 2012.
I have attached a .pdf mockup of what I want.
Steve Walton
Solved by swalton. Go to Solution.
Here's an app from the Autodesk Exhange website that might help.
That is a neat app that I can see using, but I don't think it works in the IDW environment. I will check with the program author.
Idealy, I will be able to create a part list style that I can add to my idw template and use on future designs.
Steve Walton
I solved this by creating a custom balloon style that shows the part number and weight iprops of the subassemblies. Not exactly what I wanted, but it showed the info to my customer.
Steve Walton
