I've run into a problem with a material style in Inventor. We're using R2011, and I can't remember how to do the procedure (and I just did it not 3 years ago...). I made the material by copying another similar material, renamed it, then I made a color by copying another color style, renaming and changing it. The problem is, when I make a new part with the template, the "View" material color is set to the color of whatever material is selected in the template. Before, it was always set to "as material". I can change the setting of the new part to "as material", but I can't find a way to set "as material" as the default. I checked my sheet metal template, which hasn't been changed yet, and there is a material selected in the template, but when I make a sheet metal part using this template, the "View" material is set to "as material" Anybody know 1) what I did wrong that caused the change in default setting, and 2) how do I correct it. Thanx.
Solved by LonesomeJoe. Go to Solution.
