Inventor General Discussion
Distinguished Contributor
eveylynne
Message 1 of 5 (290 Views)
Styles editor idiot moment
290 Views, 4 Replies
04-03-2012 10:15 AM
Long short, I wanted to rename one of the default layer, "Visible," to "CUT" since that's what our plasma cutter looks for.
However, I created a copy of Visible named CUT.  Now when I open a new drawing, I get the usual, "The following definitions in template Blah differ from the definitions in the style library..."
I know I could update each template, but I'd rather just delete the copied layer in the styles library.  However, I don't see how.  Any tips on removing my extra layer with out starting from scratch? Or how to rename a default layer?
Thanks!
Did you try RCing on the layer in the styles and standards editor and purging it?
Cadmanto
Message 2 of 5 (275 Views)
Re: Styles editor idiot moment
04-03-2012 11:09 AM in reply to: eveylynne
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
eveylynne
Message 3 of 5 (257 Views)
04-03-2012 12:13 PM in reply to: Cadmanto
Yeah, nothing shows up to purge. :smileysad:
(moments later)
However, I appernetly just needed to relaunch Inventor.  It worked this time around! thank you!
Cadmanto
Message 4 of 5 (240 Views)
04-03-2012 01:20 PM in reply to: eveylynne
Your welcome.  Glad it worked out for you.
Best Regards,
Scott McFadden
hareshbhere
Message 5 of 5 (159 Views)
Style not updating for Old Drawing
12-22-2012 01:40 AM in reply to: eveylynne
I have renamed one of the layer from "Engraving" to "UBENDLINE" as our laser is looking for. Now I have to update all old drawing for new layer.
When I tried to update old drawing for styles, it is not updating style i. showing old layer "Engraving". Same I tried with new drawing, it is showing correct layer as expected.
Please suggest me solution for updating old drawings.
