Long short, I wanted to rename one of the default layer, "Visible," to "CUT" since that's what our plasma cutter looks for.
However, I created a copy of Visible named CUT. Now when I open a new drawing, I get the usual, "The following definitions in template Blah differ from the definitions in the style library..."
I know I could update each template, but I'd rather just delete the copied layer in the styles library. However, I don't see how. Any tips on removing my extra layer with out starting from scratch? Or how to rename a default layer?
Thanks!
Solved by Cadmanto. Go to Solution.
Did you try RCing on the layer in the styles and standards editor and purging it?
Yeah, nothing shows up to purge. 😞
(moments later)
However, I appernetly just needed to relaunch Inventor. It worked this time around! thank you!
I have renamed one of the layer from "Engraving" to "UBENDLINE" as our laser is looking for. Now I have to update all old drawing for new layer.
When I tried to update old drawing for styles, it is not updating style i. showing old layer "Engraving". Same I tried with new drawing, it is showing correct layer as expected.
Please suggest me solution for updating old drawings.
