I have created some new layer and Text styles.
I would like to set the new Text styles to the new layers, but cannot find a way to do so.
Anyone point me in the correct direction
You can't set a text style to a layer. You have to set object types to layers in the Object Defaults portion of the Style & Standard editor. So, for example, you could set all leader text objects to use one of your new layers.
Of course, you can always set an individual annotation to a layer by selecting it and choosing a layer from the drop-down menu on the Annotate tab.
Hi swordmaster,
Go to the Manage tab and click the Styles Editor button, then located the Object Defaults node in the left pane.
Click on it so that the right pane displays the various object defaults, then use the Filter drop down to filter for only Text Objects. You can then set the default layer using the drop down box on the right.
I hope this helps.
Curtis
If you go to the styles editor, select the standard you are using under the "Object Defaults" tab you will see the text line.
Then under the object style column edit that to be your text you just created and then under the layer colulmn choose the one you want. You have to choose the "Edit" button at the top first before you can change it.
Thanks for the quick replies, I never get too involved in layers in Inventor so i am in uncharted waters!
I will try each of your solutions and see which works best!
thanks
Okay, this where i have got to with this
I created two new text styles
I opened my standard and placed a check mark next to these (under the Available Styles tab)
I created two new layers and similar to the text styles placed the check mark.
Now (and i did not mention this in my earlier post!)
I created a two new Table styles each table uses one of the new text styles. That works fine!!!!
However i can see NO way to get the text style in the Table to use the new layer.
I can change the whole table to that layer, but really i need to change just the text
Any suggestions
You can't set a style to be on a specific layer, and you can't set a layer to have a specific style. They are both independent properties of a drawing object.
In your case, you can set the object default for General Table to have your custom table style AND your custom layer. What this does is when you place new tables, they will automatically be set to have the custom table style and be on your custom layer.
But this isn't the only way to set the properties of a table. You can also create a table, then select it and change its style to your custom table style (by using the style dropdown on the Annotate tab). You can also select it and change its layer to your custom layer (by using the layer dropdown on the Annotate tab). This will only change the style and layer of the selected table, not any others.
