Inventor Forum
Style library migration 2012 to 2013
6 REPLIES 6
DRudaz
2183 Views, 6 Replies
I have installed the 2013 version of Inventor Professional 2013 in French version.
I can't migrate the style library. When I open it on the utility to migrate the button migrate is grayed.
And in Inventor i can not activate this library. Inventor tell me that styles are missing.
any idea ? Bug or not
Regards
Dom
6 REPLIES 6
Carl_mgfx
in reply to: DRudaz
Hi Dom
I am having this problem as well as some of my customers.  Hopefully someone can clear up if there is another way to do this, as it seems the normal way by using the Style Library Manager is not working.  Is there something we are missing?
Kind Regards
Carl van Rooyen
Application Engineer
Inventor 2019, Vault 2019,
HP ZBook 15u G4, Win 10 64Bit (ver 1709), i7-7500U, 16 GB Ram
Intel HD Graphics 620 with AMD Firepro W4190M
pierre.masson
in reply to: Carl_mgfx
Hi All,
Try to rename Lighting.xml so it  is not available anymore, and restart the Migration manager.
Pierre Masson Product Support Specialist PS MFG EMEA Autodesk, Inc.
DRudaz
in reply to: pierre.masson
Hi Pierre,
All is ok. Thank's for your help.
Regards
Dom
Carl_mgfx
in reply to: DRudaz
Hi Pierre
Thanks for the fix.
I am however having problems bringing through Materials and colours.  I have used the "Migrate Inventor Styles" option in both the Material Browser and Appearance Browser.  This worked to create a new Library in each instance.  Although when I start a new part or close inventor and reopen a part, this Library is no longer available.  I have to open it every time.
Is there another way to Migrate the Material and Appearance styles to have them available in all existing and new parts?  Have I gone wrong somewhere?
Kind Regards
Carl van Rooyen
SBix26
You will have to add the newly created libraries to the project you're using, I think.
Carl_mgfx
in reply to: SBix26
Hi Sam
Thanks for the reply.  Yes adding it to the active libraries for that project worked.  Although this is not the best workflow for a large firm with many designers and projects.
A work around we've found is to import the 2012 Material Library into the Material and Appearance Libraries of 2013 and then add the required or custom materials to the default Inventor 2013 library.  This may take a long time to do, but once done the libraries will not have to be linked to each project.
Kind Regards
Carl van Rooyen
