Inventor Forum
Style library for default drawing template
1 REPLY 1
dadirohith
287 Views, 1 Reply
I have a default drawing template as the bottom one on the file attached,which has a specific style definitions. When I try to do a new drawing from the same template it differs from the definitions in the style library and uses the definitions in the style library which appears as the top one in the file attached.(differs in text size,format etc.)
Any help
Rohith
1 REPLY 1
mdavis22569
in reply to: dadirohith
Did you save it out ....
Also what happens if you go Manager and Update?
Mike Davis
